2 pin fan extension cable?
12 Mar 2007
UK
Does anyone know where I could get one of these? Can't seem to find one anywhere! Basically, I want to replace the fan on my media player. The replacement fan cable isn't long enough so I need a 2 pin extension cable. Thanks!
You will have to make one!
Or you could cut the wire, solder in longer ones, heatshrink the joints and viola! Done for pennies.
That would have been my suggestion too.
Okay, the initial outlay for your wire might be more costly than an extender, but then you can extend any fan wire you like for a good while :)
Thanks Phillydee. Looks like I will have to make my own! I'm amazed that you can't actually get these. The only one I could find was on ebay US. Very odd but thanks!
