2 problems! help needed!
2 Sep 2010
i recently finished my build and i have 2 problems.
1. i cant get my memory to work at the proper speed (corsair dominater gt 1866 ) on my rampage 2 extreme to run at 1866 by using the xmp. i activated the xmp then restared my computer then it says locked on the little post it screen and i have to hold the power button to turn it off then when i turn it back on it comes up overclock failed then i change it back to normal then it works ok. so being a bit of a noobie to this i havent a clue what to do next.
2.when i turn on my computer after the the screen where you can get bios just after then it comers up saying cpu fan error press F1 to continue. is it because im using a pwm splitter? http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK
many thanks Alistair.
Regards no2 I had this issue and found it was becuase it was spinning below the expected minimum rpm.
Assuming it IS running there is probably an option in the bios to ignore the fan rpm. Can't remember the exact setting off hand though and probably depends on board model.
