2 Questions - Mousemat and GPU
24 Apr 2010
Hello all 2 quick questions for you.
Will the ATi 5850 priced at 200 on here be better than the GTX 460 sonic edition.
and
Whats the best mousemat on here under 20
Any help would be awesome.
Thanks.
Thanks. The will the overclockers UK value one be fine or will I need the sonic version if I wanted to overclock?
Hang on if the 465 is the same price? Is it better being a model up?
the ocuk models are usually inno3D or sparkle models.
the 465 is not worth the cash, its often slower, it may have more stream processors, but they run slower.
