New PSU & SSD Deffo...
Those PSUs are horrible.
how does this look
5830
http://www.overclockers.co.uk/showproduct.php?prodid=GX-168-XF&groupid=701&catid=56&subcat=1711
ssd:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-006-PA&tool=3
or is that ssd a no go because it seem's to be too cheap for 64gb
Your PSU will not handle two of these cards in Crossfire...
In terms of power 700w will be more than enough but the brand is cheap and probably can't maintain a constant power.
hmmmm thinking about the psu bit. here are the spec of my current psu so you can tell me how crap it is
.green power <70 (high efficiency)
. thermal control
. over voltage protection : +3.3v, +5v,+12v
. suited voltage ac input 115/230v
.100% burn in test / vibration test/ hi-pot tes/leak current test
.special pfc technology
.2.0 or 2.2 version support dual core and multi core gpu tech
. 2x pci-e connecter for multi gpu
.700 watt
also if it would work well or last long with 2 gfx cards/ ssd's whatever?
None of these specifications mean anything. Its the Amps of the Rails of the PSU which is what you need to check. Even if these are within the recommended limit (which I doubt) I think your pushing a generic PSU to its limits as it is with that your running tbh...
What you need to ask yourself is:
Is it really worth skimping on the power supply in the hope to save a few pounds at the risk of it going and taking some if not all the other components of your PC with it?
Only you can answer that one...
for a psu i will need something with at least 4 6pin's with correct amps, an so on.
im not very up todate with psu's either so please excuse that, and prferably a modular psui
no i don't have an ssd at the moment,if i did get one it would be a boot drive though and as i have said selling the 5830 is not an option as i have just got it and tbh imo it is a lot better card than everyone is saying it is runs most games at 4000x1000 maxed out no prob at 60+fps it's just a few that i have to turn settings down, this is with an overclock ofc tho
i think not taking the advice of others here and keeping the 5830 is just foolish listen to peoples advice all the people in this thread cannot be wrong and you be right
this is a lie, fool yourself all you want but it is
http://www.anandtech.com/bench/Product/171?vs=158
that is your card vs one of mine and i know for a fact my card would not run 60fps @ that res on the games i play
you are either having every single pu setting turned off you you are playiing lemmings
if you want to game with new games at decent setting ditch the bottom of the range old gen 5830 for somthing else, dont add another crap graphics card to make the situation worse by using more power, making the case hotter and making your system louder.
a single gpu option is always better, adding a second is an advantage when you are at the top end of graphics cards but not when buying basic budget cards.
psu is now on the top of my list as for the cx600 shouldn't i go for something a little more powerfull and maybe modular
