Coil pack + plugs + leads will be around £100 in parts tops. Easy enough job to DIY too really.
I'd change the lot, then it's job done. 90% sure it's likely to be this.
Is it petrol or diesel?
Were the dashboard lights on when you tried to start the car?
You'd need a multimeter to do a continuity test on the clutch switch if:
1. A visual inspection to see if it's seated correctly in the metal support bracket come up as o.k..
2. A physical test involving pushing the plunger in/out doesn't give any obvious signs of a fault like sticking or a harsh feel in its operation.
The clutch switch will be open circuit when the pedal is not depressed, the plunger comes out as the pedal is depressed which closes the switch.
Crap advice tbh.
It'll end up costing you more in the long run.
The car has a lumpy idle and causing the engine light to come on. As already said the garage tested it and the code was cylinder 4 misfire but no misfire found by the garage......that said the idle is still lumpy after a coil pack and HT lead change. The cost of the car is irrelevant really, i would rather have it fixed for than have to buy another because the fault turned out to be serious enough to do some damage. I agree i would rather not spend another £40 to get another diagnostic done.
If it's running fine then it's probably fine.
