2006 system upgrade for BF3
30 Nov 2010
UK
Hi I am looking at upgrading my system to be able to play Battlefield 3 at reasonable settings, it doesn't need to me Ultra just medium and smooth would be fine. I want to do it as cheap as possible as i mainly use my mac for everything, this will be just for Battlefield.
My current system:
Intel Duo E6600 overclocked to 3ghz
4GB DDR2 Geil 800mhz
Asus P5N32-E-SLI
Antec 900 Case
Antec TruePower Quattro 850W PSU
BFG 880GTS 512MB
500GB eSata 5400rpm
Any help would be great!
7 Oct 2008
Cheshire
My current system:
Intel Duo E6600
Asus P5N32-E-SLI
Antec 900 Case
500GB eSata 5400rpm
What graphics card do you have? That's going to be the biggest factor.
21 Oct 2010
What resolution monitor have you got?
And by "reasonable settings" I assume you mean mid-high?
OP
30 Nov 2010
UK
Sorry forgot to mention already overclocked at 3ghz I did have it at 3.4ghz but temps were way to high.
budget is max £400 would like less then £300 if thats possible.
Just another thing I thought to mention I have played the Beta at lowest everything in the way of settings and I have massive lag, just incase you look at the BF3 min settings and see i should be able to play it.
13 Sep 2010
the E6600 might struggle a bit, even overclocked. AMD Phenom quads start around £70 but you'll need a motherboard too, which start around £50 and £30 for DDR3 RAM.
IF you need to buy a new graphics card, a 6850 would be fine and start at just above £100
If you've got the money I'd spend an extra £20 on the cpu and get the 965BE CPU as it will OC easier if needed later on, and comes with deus ex, which you could sell if you don't want to play it.
most 6850s come with another copy of deus ex, and some with dirt 3 as well
However, if you don't want to spend any money which isn't needed, you could wait till next month, and see if OCing your CPU (perhaps upgrade the cooling) made it playable with all settings on low, I bet it'll still look great!
21 Oct 2010
Not 100% on this, but should be a good start.
YOUR BASKET
1 x HIS ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card with DIRT3 & Deus Ex PC Games £109.99
1 x Gigabyte 990XA-UD3 AMD 990X (Socket AM3+) DDR3 Motherboard £94.99
1 x AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail with FREE Deus Ex PC Game £89.99
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £23.99
1 x Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) £19.99
Total : £350.95 (includes shipping : £10.00).
The motherboard supports crossfire 8x/8x and bulldozer, so should have a good upgrade path.
6850 is a good card and comes with two free games.
Freezer 7 should give you some OC headroom.
7 Jul 2010
Why dont you just grab a better heastsink and have your cpu @ 3.4GHz and grab a 560Ti?
Corsair A70 32.99
GPU 167.99
Total 200.98
Then when you can afford it upgrade to sandy bridge 1155
27 Jan 2011
London
YOUR BASKET
This is a wonderful spec.
8 Sep 2011
Northern Ireland
maybe a second hand q6600 (~£50) and overclock it and a 6950 2gb (£200-250). you also have an option of buying a cooler for ocing the q6600.
im also thinking of doing this, replacing my e2140 @3.2ghz
29 Dec 2005
I've got a very similar setup and was thinking of upgrading my gfx card, then later going for a complete overhaul. Will the e6600 (or my 4x512mb 533mhz ram) bottleneck a newer generation gfx card like the 6850/6870 or 560Ti ???
20 Jul 2005
Earth
I had a e6600 running a 6950 2gb, and recently upgraded to an i5 2500k, 8gb ram, and it was a massive improvement. Really opened my eyes to how much my cpu was bottlenecking me. Some games went from a 40-50fps to pushing 100+ without vsync, really was a big difference.
Oh and its worth saying, bf3 runs perfect on one screen, i'm pushing it trying to run in eyefinity @ 3x1 get between 25-35fps it almost feels like its running good enough but not quite. Making me want another 6950, pretty sure its just short on vram, at times the textures just cant update quick enough.
