Hi guys,
This is my 2nd thread (my first was a bit disorganised) so I wanted to create an new one in the hope I could get some advice from you guys with regards to building my 2013 PC.
The idea is that this is a "Work in Progress" throughout the year, adding to it over the coming months.
So, I already have a GTX 670 FTW to put in it, and plan on getting on for SLI. I also have various HDD's and SSD's for it as well. The real issue I'm having at the moment is choosing the right motherboard. I intend on overclocking the processor to 4.5GHz, The GPU's and maybe a little on the memory.
I've dabbled with Water cooling in the past, but this builld is primarily going to be on Air, although I won't rule out Water cooling in the future.
So, Ultimately, This is what I see the system having.
Triple SLI GTX670's
A Revo Card
Overclocks
Air cooled, with low temps.
So, here is what I have chosen so far.
YOUR BASKET
1 x EVGA GeForce GTX 670 FTW 2048MB GDDR5 PCI-Express Graphics Card £319.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x NZXT Phantom Enthusiast USB3.0 Full Tower Case - Orange/Black £96.38
1 x Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (PV316G213C1K) £89.99
1 x Phanteks PH-TC14PE CPU Cooler - Orange (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £69.98
Total : £771.34 (includes shipping : £12.50).
Will I fit the Triple SLI into this NZXT case? I love the design of the NZXT cases, so ultimately I want to go with that if possible.
Also - which PSU do you recommend? It seems a lot of the big W ones are now out of stock which is a right pain in the ass.
Can you help me pick the right Mobo, Case and PSU for this build?
Budget is £1400.
Thanks
Triple SLI GTX670's
A Revo Card
Overclocks
YOUR BASKET
Budget is £1400.
Thanks
