2016 R1 Engine surge
29 May 2010
Tampa, Florida
Towards the end of the video you can see the engine RPM going up and down.
Between 3-6k rpm at a constant part throttle, in gear riding, or in neutral stopped, the engine surges.
I changed the spark plugs last month and have only ridden it a few times since, but the past 2 rides I've noticed this surge and can recreate every time.
-Replaced the gas
-Checked for kinks
-Checked for any air leaks
-Re-flashed the tune to make sure it isn't that
-Gave it an Italian tune up.
Above 6k rpm or with big throttle inputs it's perfect, pulls like it normally does, just that 3-6k surge on cruising throttle.
Any ideas?
Man of Honour
13 Jul 2004
Is your exhaust servo functioning properly? That disables at 5.5k rpm if I remember correctly which might be why it clears up after that point.
18 Oct 2002
Northants
Im assuming its the same as the Mt10 and has the exhaust valve on the cat ? have you removed the cat ? if so and not had it mapped .. get it mapped.. My MT10 was pretty rough after removing cat and valve
OP
29 May 2010
Tampa, Florida
Figured this out.
I have an ActiveTune module from FTECU which has AFR targets it constantly adjusts to meet... it seems it is now faulty as I can switch it off in the map and the bike runs fine.
8 Sep 2006
uk
Figured this out.
Thanks for taking the time to say what the problem was.
I have the same bike, so its always handy to know these things
