206 Climate control problems
Sam
Sam
12 Jan 2003
Surrey
Hi Guys
A friend of mine has a 206 1.4 which has climate control. A few months ago it started blowing on full all the time and it couldn’t be turned off. The only control allowed by the control panel was either fully hot or fully cold. She took it to a garage and they somehow disconnected it so although the control panel displays as normal nothing works.
Now I’m thinking about just buying a new climate control panel as you can get them off eBay for around £40 but do you think that will resolve the issue ? Any Pug nuts here who could help me
Many Thanks
Sam
Its an 02 mate, i called Euro car parts and they have said thats the correct one
Just trying to find it cheaper now
Hi
Out of interest she took it to a garage recently and they some how disabled it from working. The display still shows but it does nothing. Do you guys think its just a simple fuse that needs putting back in, how else can it have been disabled
Cheers
Blast Radius
When you say remove the glovebox i assume you mean moving the glovebox door / innards ? i managed to get under the glovebox and found they had simply unplugged the 2 x connectors to the blower motor. re connected and as predicted its just blowing on full all the time. Going to order a new one, did you say its just twist and clicked on or do i have to remove screws etc. It looks a bit of a nightmare
Cheers
Sam
bump ?
Could do with some help removing the glovebox, im attempting this tomorrow ;-)
Hi mate
Nope ordered that part and fitted it last night, only took me about 30 mins and it solved the problem :-)
Thank you very much for your help
Cheers
Sam
