Hey guys,
Looking at the Gigabyte varients of these cards..which is the better card?
Im also bearing in mind the driver issues with the AMD cards, against the RTX..
Nvidia have their fair share of driver problems, so i wouldn't factor that into the equation.
That being said they are both similar performing cards and perform almost identically , in a few games the 5700xt is ahead in others the 2060s is ahead.
If anything i would sway towards the 2060s , Nvidia cards are still easier to overclock and tend to yield better results imho.
Hey guys,
6 months now
OK, 5 months and 13 days then.
Didn't you have a few weeks where you couldn't install? Beginning of August? Only reason I said the 5 is because it sticks in my mind!
edit - I'm heading into The Time Tunnel to find out!!!
https://forums.overclockers.co.uk/posts/32874399
https://forums.overclockers.co.uk/posts/32898746
I was 3 days out![]()
/yes I'm bored atm
But feels like ages
And I was 10![]()
But feels like ages
It's serving you well man, and some nice gains lately on drivers![]()
How long do you want to keep it for? Personally I'd weigh RTX & VRS & Mesh shaders more heavily long term than the raw power advantage of the 5700 XT. But if you really want the value option, I'd rather look at the 5700 in the first place. With a few tweaks you're more or less getting a 5700 XT for quite a bit cheaper.
I thought the 5700 did VRS?
