2080 Ti Cooling options
28 Jul 2014
So basically i have 2080ti dual and 3900x CPU, and i want to reduce size of that to make 2nd GPU slot accessible.
Currently i tried kraken G12 and X62 combo, but unfortunately this one is too big.
So i need go for another options.
First i found what i can buy Alphacool Eiswolf 240 GPX Pro and install on my GPU, but people saying that this is not full cover and gpu will have only passive cooling from large heatsink
Later on i saw on reddit post from one guy who recommended instead go for Alphacool-eisbaer-360mm
https://www.overclockers.co.uk/alph...u-aio-water-cooling-unit-black-hs-009-ac.html, buy extension tubes, GPU waterblock - https://www.overclockers.co.uk/phan...-block-with-rgb-lighting-black-wc-02b-pt.html, something like this and connect them all together and have cooling for GPU and CPU
So my question is:
Is it worth it to go for 2nd option, or 1st one will be enough? Currently CPU cooled though Corsair H110i GTX
Or start a custom loop without CPU, for me it will be most expensive option, and i dont want to spend much now.
Or can be another solution? Can't use GPU vertical mount, not enough for 2nd anyway :(
PC case is Phanteks P600S.
