Can anyone with experience comment on the PPI in relation to browsing web pages etc and general daily use for home?
Nothing productive.
Thanks.
Thanks for the reply.
Have been using a 27" 1080p for the last year so I do not think it will be a problem.
I've recently tried a 29" 2560x1080 display recently, it's a nice display, the colours are good, but the PPI is the issue. It's just way too low. It would be so much worse at 34".
2560x1080 29" UW is about 100 ppi, that should look good.
You don't normally sit a foot away from a large monitor though so the comparison is moot.My laptop is about 300, and my iPad pro is about 260, so I might be a little bit biased against "low" PPI displays.
Stating that something would be too low for desktop for desktop use is totally subjective. A mate of mine deliberately didn't go for a higher res display as his eyesight isn't as good. Other people may do it simply because they aren't bothered. It's a very individual thing. It DID bother me in the end, so I upgraded, but I had no real problems other than my personal desire to want more real estate, greater sharpness etc.
I actually do sit around a foot away from my monitors.
I think it's less about subjectivity, and more about what you get used to. Lower PPI displays can and will look fine, until you get used to a higher PPI display, then you suddenly notice how low resolution it looks.
Then you're sitting too close. 29" UW will look fine, higher DPI.
You don't need mobile phone PPI on a monitor.
Surely you don't sit as close to your big monitor than you do a tablet or laptop???
If you really do, I doubt you'd be happy with anything shy of 4K. That's not most people though...
It depends, it's probably around the same. It isn't quite as obvious how big the difference is between them though until you get used to using high PPI displays. You don't have to be able to see the individual pixels to actually notice a huge difference in resolution.
Too close isn't really a thing. However, I can sit 2 feet away, 100 PPI still isn't "enough" now that I'm used to high PPI displays.
Oh yeah, I definitely use scaling. But it's also because I am generally used to high PPI displays.Baring in mind I use 1440p on my main monitor but I find the 1080 vertical resolution a bit limiting on my UW.
A lot of people don't use display scaling like I'm assuming you do so won't notice it quite the same.
29" 2560x1080 is practically the same PPI as a 24" 1920x1080 display - 96ppi vs 94ppi. They are both acceptable but there should be no doubt that displays with a higher PPI are noticeable sharper and better to look at as a result. i flip flop between a 29" 2560x1080 ultra wide and a 34" 3440x1440 Uw and honestly the 34" is sharper than the increase to 110ppi would suggest. It's a clear difference. 27" 1920x1080 and 34" 2560x1080 also have the same PPI - 82, so that's on it's way to being the same difference in PPI but in the wrong direction. I had a 27" 1920x1080 panel and i didnt mind it at first but now when i see those panels in use at work, they are SO soft in comparison to my 34" UW.
