22" an 40" dual problem... help?
6 Oct 2007
Liverpool
i have 2 samsungs....22(primary) and 40
now i turned off my screen saver but if i am watching something on fullscreen on my 40 after a while the TV will turn off and i cant find a setting to stop it.
also my 22 does it after a certain time.... so am little confused.
i havent checked my graphic settings yet which could help.
as i am watching something i am not moving the mouse etc so goes to stand-by.
any help would be greatful.
Thanks
On Vista try:
Control Panel -> Power Options -> Change Plan Settigns, under Balanced (Guessing you have balanced plan selected (default)). Then set Turn Off Monitor to Never
Must be something similar in XP if you are using that.
You are a star! thanks man, i knew it wouldnt be a setting in the TV (40") coz it is recieving a signal from the PC. so was the PC thinking am not there and turning monitor(s) off.
yep yep ... thanks again! !!
