Permabanned
- 15 Dec 2008
As above.... Moved to water cooling from this...
Didn't worry myself with temps or voltage as the cold reduces there effect on the chip but want to play it a bit safe now I'm on water.
1.45v ( Load voltage ) good for 24/7?? Not really concerned about reducing the chips life span but don't want it to degrade either.
And what about safe temps? Used to run at around -30c loaded under phase ( Evap was -46c so 15c delta between CPU and EVAP temp seem about right )
Also, how do I get an MSI board to drop the voltage during idle?? As soon as I set Vcore manually Intel speed step doesn't seem to work with it enabled???
To reduce Vcore would I need to push the PLL up or down?
