24" LCD Monitor for PC + PS3
24 Aug 2007
I want to get a 24" LCD but not sure which one to buy; i was looking for one with DVI + HDMI ports for pc and ps3 for around £300-£400, any suggestions?
I've heard some good things about the Hyundai 24" TN screen, unfortunately i don't own one myself so I can't really give you a personal opinion on it in regards to ps3 quality etc.
hi
i have the hyundai tn panel (w240d) and it is a very good monitor . its very stylish and has a lot of connections . the veiwing angles are a lot better on this than my old 19 inch . the only thing i dont like about it is the backlight bleed its quite bad but after a while you tend not to notice it . living next to a train line scenario .
would deffo recomend it. its great for looking on these forums in 90 degree rotate mode you can see so much more.
cheers
hi
cheers
thanks for that, but i think i will notice the backlight bleed; now that you've brought it to my attention. The viewing angles wont bother me, i will only be looking at it from one angle anyways; head on.
the viewing angles will bother you, especially the vertical ones.
