2407WFP-HC Not level :(
25 Dec 2005
Got this monitor today but when i twist the screen back to the landscape mode it tilts slightly to the right still. As if it cant go any further for it to be straight. Is there anything i can do to adjust it?
i think you need to take it apart and tighten some things or something. All of them are like it but i think it can be modded. But tbh i think its really lazy designign and not on for such an expensive monitor when other's dont do it.
dont worry it happens with them all, the transformer in most modern lcd monitors is placed on that side, i get it on my benq as well, at the start its a bit weird but you soon get used to it
I had the same problem with mine. Just adjust the four silver screws on the bit of the stand that clips into the back of the monitor
