240mm AIO radiator location
I personally wouldn't go above 1.35 for 24/7 and only if your temps are in check...
cheers, i thought about overclocking last night but the idea was to get the temps down not get tehm down and clock more to get the heat up. plus the difference between 4.8 and 5 i presume is minimal
cheers again
My cpu can run 4.8 @1.34v but I'm still using 4.5 @1.2
Its good to know your max overclock and save a profile in bios so when you need it you just apply it ::
