24GB of RAM, would it work ?
17 Feb 2009
HX424C15FB/4 they're the 4GB modules.
HX424C15FB2K2/16 are the 8GB ones
I currently have 2x8GB installed. But have some RAM lying around and wondering if I can install these as well ?
Slot 2 and 4 have the 8GB
Slot 1 and 3 could have the 4GB ?
B450 Tomahawk Max mobo
Ryzen 5 3600
Not planning on overclocking
You could but the ram more than likely won't run it un dual channel or triple channel mode. The duel/triple mode is for speed.
Theres no triple channel mode on AM4.
Yes OP it should work, and it will work in dual channel mode, timings and speed will drop to the slowest sticks.
Do you ever use above 16GB though?
Good question.
More ram is only for multi-tasking right ?
When I went from 8GB to 16GB I noticed no difference, PC was still speedy.
In cyberpunk it uses up about 45% of the RAM.
The only thing is, if it's lying around not being used I may as well install it ?
