That's it. Ordered the Samsung! lol
I decided Samsung too, going to have to wait until the begining of next month as just had to fork out on two unexpected new car tyres...
Post your opinions when you get it mate....
Samsung should be better, they make good quality monitors.
Been trying this baby out for awhile now and I absolutely love it!
So far I've been playing Crysis and AVP on it and they look amazing! The build quality is superb as well; it really does ooze quality. Blue LED on the front and touch sensitive buttons as well - very stylish!
The stand IS adjustable - I'm unsure what the other reviewer was on about. It doesn't tilt side to side but moves up and down perfeclty fine.
So far, 5/5. Can't fault it really. 1080p movies look awesome. Good purchase methinks!
Had my B2430 delivered today.. So far its a bit so so ...
Anything i use on the HDMi results in a very blurry picture, Text on icons is blurred around the edges. Even the Xbox 360 via HDMi looks blury it lacks definition.
If i use VGA its razor sharp, so i,m thinking it must be a setting somewhere ?
Anyone any ideas...
Cheers
I have gone through every setting and the Pic on this monitor via HDMi is awful..
Just called OC tech support and the chap said all samsung monitors look rubbish on HDMi. so it looks like i will have to return the monitor as its unusable reading this webpage is almost immpossible as the text is blurred out of focus.
Its a shame when using VGA it is fabulous but i need the HDMi to work..
That's a lie. I am on my samsung monitor and connected with HDMI and the picture is brilliant!
Why would i lie ??
It could be a fault with this screen but the pic is awful when using the HDMi..
No I was saying it's a lie the fact that you said the support guy said all sanding monitors look horrible on hdmi.
There may well be a fault or you can check up on google.
