- 25 May 2011
Just wondering
i've got a 2500K @ 4.4 Ghz on stock volts. Don't want to put more volts in it for minimal gains. So I take it the 2500K is still good for the next 2-3 years? so long as it has around 4.4Ghz - 5Ghz overclock.
Not really. The 6600K at stock isn't good for 2-3 years.
Remember Intel have stagnated the market with mainstream 4C/4T chips. Now that is changing.
so you reckon in 1-2 years time a stock 6600K will struggle to play the latest games and your GPU will demand a CPU upgrade
Whether it's "adequete" for whatever purpose (which you didn't mention) isn't what the OP was asking though. The question was quite specific. I wouldn't get a 4c/4t CPU for any serious rig now but hey ho.Guys, 2500K isn't adequate even at 5Ghz. Last year upgraded from 4820K @ 4.9Ghz (and briefly to 4930K @ 4.5) to 6700K @ 4.8Ghz and there was a HUGE jump in performance across the board.
Since moved briefly to 1700X @ 4ghz and 2 months now to 6800K @ 4Ghz and not looking back. Everything runs even faster than the 6700K @ 4.8. Let alone the 4820K
That sounds like a realistic expectation, although remember you're comparing an older, lower clocked, CPU with a newer, higher clocked one, which also has SMT.I went from a 2500k at 4.3ghz to a 6700k at 4.6ghz and it is definitely smoother and more consistent frame rates for playing games. I wouldn't say night and day difference though.
It'd probably have to be even lower than that considering a decently clocked 2c/4t Kaby Lake chip is regularly ~£50.I wouldn't recommend any 4c/4t CPU unless it is less than £100.
My 2500k struggled to hit above 4.2ghz and my 7700k does 5ghz so an 800mhz difference probably helps as well as RAM that's literally twice as fast
