Salutations,
So about 20 minutes ago I was playing borderlands 2 with a friend when I noticed massive slowdowns. I have a keyboard with a display and I switched to the CPU/RAM monitoring application and my CPU was hitting 100% load. I then began to monitor it for the next 20 minutes and it seems that I'm constantly around 64% - 80% with spiking of 100%. I asked my friend what his was running at and he said about 30% - 50%. I then tried closing some useless processes and turning the graphics to low but it didn't make any difference. I then restarted my computer thinking maybe it was just a hiccup but unfortunately that was not the case. I've just tried playing on Counter Strike GO, now usually I'm about 30% load with this game but I was at a solid 90% - 100%. Below is a screenshot if that's useful.
This is just after I closed counter strike.
The CPU idles just fine like now whilst web browsing listening to music and typing this out I'm not getting any spikes nor going over 10%. And the last system change I did was installing the BETA Nvidia drivers about a week ago.
I'll try uninstalling the driver tomorrow but any suggestions in the meantime would be very helpful.
Specs:
I5 2500K @ 4.6Ghz
8GB RAM
GTX 680
regards -Skeng
Specs:
I5 2500K @ 4.6Ghz
8GB RAM
GTX 680
regards -Skeng
