- 12 Jun 2024
- UK
So I'm reviving some old equipment to do a retro build which will double up as an home general use pc and a cheap gaming rig for older games
Couple of questions
I want to overclock it I had a previous 2600k at 5ghz that saw some big gains in performance. I'm looking for cooler recommendations, will the thermalright assassin king se at £17 do the job for a high overclock or will I need something bigger like the phantom spirit se?
What's the best possible ram and GPU I can go with for this set up basically wanted to get it as good as it can be Motherboard is Asus genie v.
As I understand it the 2600k is soldered and overclocks very well on average and there is very little difference in performance between them at stock but I've got an untested 3770k that came with some spare parts I bought any reason to go with that over the 2600k I don't want to generate any unnecessary heat in a fairly small form factor build and don't want to delid or anything.
Couple of questions
