Hi,
I received my system this week from the Guys @ OCUK (excellent service as always)
Brief Spec as follows:
I am currently only getting 4.3 gHz out of the processor, which was stable after 20 passes of Linx (about 2 hours)
I upped multiplier to 44 to get 4.4 gHz, but it failed after about 44 min, and then 22 min.
Is there anything else I can do to get it more stable? Up voltage etc?
Current Voltage is 1.320
Are there more relivable stability tests I can run?
I am sure there is more to give from the processor?
What is the option in the bios to disable "Turbo" (if that is what it's called).
I read that it's best to disable it during OCing, but I'm pretty sure it's enabled as CPU-Z is showing core speed if 1600 MHz (but reads 4300 MHz under load)
Further steps will be flashing gfx cards to 6970 (I have the dual bios switch), and doing some OCing there too.
Also, any advise on OCing my memory?
- Gigabyte P67A-UD4-B3 Intel P67
- Intel Core i7-2600K
- Corsair XMS3 8GB (2x4GB) DDR3
- OCZ Vertex 3 240GB 2.5" SATA-3
- Asus ATI Radeon HD 6950 OC 2048MB x 2
- Coolermaster Silent Pro Modular 850W Power Supply
