So my ROG Swift PG278Q has died, again. Exactly the same symptoms as the first time it died within a month of buying it new. Pixelated/poor quality text and flickering in the top third of the screen.
I'm in a quandary as to what to do now.
My absolute must haves are:
2560x1440
27" (Although might consider bigger if the price/specs were right)
G-SYNC or G-SYNC Compatible
I am torn between an IPS Panel or TN and whether I should look to somewhat futureproof by going for a G-SYNC Compatible FreeSync panel if I ever move away from my RTX2080.
In terms of my requirements the only panel I have found which is Freesync G-Sync Compatible is the MG278Q ROG Dominator 27".
The other models I am considering are:
I note the Aorus AD27QD is a newer 1MS IPS panel at a reasonable price but is not G-SYNC Certified, many reports of it being fine around the place though. Anyone got any experience?
Thoughts? Anything I have not considered which may be a better option?
2560x1440
- Acer Predator XB271HU (165Hz, IPS, G-SYNC) ~£600
- ASUS MG278Q (165Hz, TN, Freesync/G-SYNC Compatible) ~£420
- ASUS PG279Q (165Hz, IPS, G-SYNC) ~£670
- ASUS PG278QR (165Hz, TN, G-SYNC) ~£560...although the 278Q Freesync/G-SYNc Comaptible model apepars to be the same panel but cheaper.
