I was looking at buying the 2700k that's on offer do you think that would be good for gaming at 1080p for the next 3 years?
I use one for gaming and general work.
But it depends of your going to utilise the extra hyperthreading cores, most games can just utilise 2 cores
But a good alternative is the 3570k:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-404-IN&groupid=701&catid=6&subcat=567
and I heard a few of the better games use the hyper threading? Using the onboards graphics or a dedicated card?
What graphics capability you plan to use is more of a concern for gaming.
I normally just play the high graphics gamesand I heard a few of the better games use the hyper threading?
Would the 2700k be better at gaming than the 3570k? I don't mind if it's only better on a few titles but obviously if it isn't better at all I will just get the 3570k.
I have a 660ti and I plan on getting the 770 when it's released.![]()
Personally i'd go for the 3570k. HT not needed that much for gaming ( in fact I Don't even think any games use it) The OC ability of the 3570k and its better performance in games probably of more use to you.
Could you recommend me a cooler to go with it?
Ha very good choice of card and will be very capable for a long while.
A 2500k or 3570k would be most peoples choice for a new processor for gaming. Not sure hyperthreading is going to help in the majority of games but over 3 years the price difference of the 2700k will not matter too much.
I am running a core i5 760 and that will be good enough for gaming when paired with a decent graphics card for a long while yet so anything faster more so.
The K2? If your case can fit it.
That's what I though the price is only £40 more for an i7 so why not?
K2 is a great cooler, but youll need low profile ram with it. Anything with fins/heatpipes will be a definite no go. I use corsair vengeance lp with mine.
Cpu wise, the 3570k will cope with the vast majority of games, the i7 cpu's such as the 2700k/3770k will only really show gains in multi gpu situations at high res above 1080p. Bf3 is one game i know of that will utilise hyperthreading that is featured on theese cpu's.
I just checked and the 2700k is only £36 more are you sure it wouldn't be better?
I don't mind paying more money![]()
2700k will be a nice choice. Im on a 3570k here, but tbh im gonna get rid of it and move to a 3770k, will benefit more with sli.
would the 3820 that's on offer be a better than the 2700k as it's newer?
