280mm rad help
24 Sep 2020
Hi,
Does anyone know of a 280mm rad thats available in 38mm thickness max? The only ones I can find are 28mm / 30mm or 45mm +
The case I have has max clearance of 63mm (38mm rad and 25mm fans)
I know this will work as you can fit the Arctic liquid freezer II 280mm in the case.
Thanks in advance
