I'll try the 14.7's, just installing now Matt. Here are my DxDiag and system specs.
https://www.sendspace.com/file/353vcc
https://www.sendspace.com/file/ttrfl5
Hello Booner,
Thanks for getting back to me with that info, I have an update for you.
This issue has been replicated and a fix is being worked on. It will be rectified in a future driver update.
In the meantime it would be really helpful if you could share with me a couple of the BSOD mini dump files. Although the issue has been replicated, it would help the driver team to have as many BSOD files to be analyzed as possible.
In most cases a minidump is created by Windows whenever a Bluescreen crash occurs. This can be found in C:\Minidump.
If you do not see such a file, try enabling it using the following instructions from Microsoft:
http://msdn.microsoft.com/en-us/library/windows/hardware/ff542953(v=vs.85).aspx
Before reproducing the issue, please disable the Windows Timeout Detection and Recovery as well to ensure only the system crash information is gathered:
http://msdn.microsoft.com/en-us/library/windows/hardware/ff569918(v=vs.85).aspx
The fix, in the meantime, is to disable hardware acceleration.
