2900 Power connectors..
17 Jan 2005
Liverpool
This has probably been posted but I couldn't find it.. Which power connectors am I mean to plug into the 2900?
At the moment I'm just using one 6pin.. But the other 6 pin will fit in it as well.. Do I need both or will one suffice?
getcarter said:
But it means he cant overclock it either doesnt it.
No, it means he can't use ATI CCC Overdrive. You can still overclock other ways.
If you want to connect all 8 pins, connect the remaining two to GROUND (black wire on molex), that works a treat :)
Ahha, I'd had a few beers last night so my search skills were lacking!
Cheers for the info! Hopefully I can get it running properly tonight.. :)
