2d clock speed too low...
22 Oct 2004
I need the 2d clock speed to be higher but i cant seem to change it ccc. Ive tried other programs like amd gpu but its outdated and dont support my graphics card.
I am guessing here as your questions wasn't that clear...
I think all you need to do is create a profile and then edit the related profile to raise the 2d clock.
Code:
<Feature name="CoreClockTarget_0">
          <Property name="Want_0" value="60000" />
          <Property name="Want_1" value="60000" />
          <Property name="Want_2" value="89000" />
The "want_0" value would be the base clock, or 2d clock.
I am not going to hold your hand on this but would suggest that there is a solution to your problem should care to google "changing 2d clock speed ati".
