He will be playing it on a 30 in hd tv. Gaming and a lot of editing are the main uses.
Looking 6 core cpu
dual graphic card motherboard - single card just now but will add on later, another card
250gig SSD as a minimum
16 gig of fast RAM
Cosmos case
high end cooler - he won't be watercooling...as in, "proper water cooling"
A high end AIO would be acceptable. If choosing a high end AIO then good fans for the Radiator to replace stock fans.
Blu Ray player with software so retail version for the trial I presume?
Top end power supply to allow, later on, dual gpu setup.
Win 7
Thinking a 290 card with the option of another 290 card later on. Want the main parts, mobo, cpu etc to be top end now as opposed to spending too much on graphics at this stage.
Does the cosmos have a fan controller?
Budget between 2k and 2.5k if it's worth going to £2.5k
Looking 6 core cpu
16 gig of fast RAM
Cosmos case
Win 7
I just heard that 290 xfire was a plum setup. A decent 780TI single card just now would also be an option.
