19 Jan 2006 at 22:26 #1 Scribes Scribes Associate Joined 19 Dec 2004 Posts 46 Location Newcastle How do you retrieve files on an old hard disk, when the old disk used w98 and current boot up is xp ?
19 Jan 2006 at 22:36 #2 noxidjkram@hotm noxidjkram@hotm Associate Joined 29 Oct 2005 Posts 2,465 Location Newcastle upon Toon Just pop it in as a slave drive, and copy the files from it. M
19 Jan 2006 at 22:37 #3 SiriusB SiriusB Soldato Joined 16 Dec 2005 Posts 14,443 Location Manchester noxidjkram@hotm said: Just pop it in as a slave drive, and copy the files from it. M Click to expand... If it is an IDE HDD then you will need to change the jumpers on the back first. There should be a little graphic that shows you how to set it. SiriusB
20 Jan 2006 at 10:13 #4 derbyjake derbyjake Associate Joined 8 Nov 2005 Posts 425 Location Derbyshire UK or the easiet and quick was is to use a usb 2 enclosure maybe your freind has one you can borrow save you opening up the pc
