- 2 Jul 2013
I have an OCUK Titan with the NZXT Phantom 410 Enthusiast Midi Tower Case - Gun Metal and I've just bought a 2nd HDD (Seagate ST1000DX001 3.5 inch 1TB Hybrid Internal Solid State Drive) to go inside.
I've seen where the 2.5" SSHD is mounted and there is a space above, and several further up. When I ordered the HDD it literally is the HDD. But none of the cables I see within the case seem to link up. Do I need to buy an adapter/cable or am I missing something?
I can get the plastic cases to slide out a bit but not fully so can't actually see how the SSHD is connected. I have several connections open ended but they aren't the same shape as the ones on the baxck of the HDD.
Does someone have an idiots guide to what I need and how to? I thought it was going to be fairly plug and play or at least come with some fitting instructions - but literally a box with the new HDD in.
Thanks
Thanks
