2nd M.2 drive
2 Nov 2013
Hi all
I'm getting a bit tight for space on my gaming HDD, so I was thinking of getting another. But I just checked and my motherboard has space for a 2nd SDD so it occurred to me maybe I'd be better off filling that slot and having a gaming SDD as well as a gaming HDD.
I've never fitted an SDD though, so thought it sensible to check my thinking in case there's something obvious I'm missing!
The motherboard is an ASUS Prime Z370-P. Has a 0.5TB SDD already in place with the OS on it.
I saw this which seems a very good deal at the moment:
https://www.overclockers.co.uk/cruc...i-e-3.0-nvme-solid-state-drive-hd-070-cr.html
Anything special I need to know about fitting? Any alternative I should consider instead?
Thanks for any advice!
Glad I checked the reviews for the Crucial P2. Was going to order the SN550 instead then checked more reviews and decided the SN570 was worth the little extra and ordered one today.
