2x 120mm fans on GPU: one as push and one as pull?
4 Oct 2014
Hi guys,
So on my RXVega 56 I have two 120mm Noctua fans stuck on top, both pushing air into the heatsink.
My question is, since I have NZXT H1, can I turn one fan around to pull air out of the heatsink and dump it outside the case?
I have a Sapphire Pulse so one side of the heatsink is straight through.
Reason I ask rather than just test is because it's a bit of a pain to setup with all the zip ties. So wanted to ask whether it's even worth trying.
With 2 fans side by side one moving air the opposite direction of other airflow tends to flow in a circle. Reason is air on out-flow side of fan is higher pressure than in-flow side, and higher pressure air move toward lower pressure air trying to equalize pressure (see image below.
