http://www.lian-li.com/v2/en/product/product04.php?cl_index=2&sc_index=5&ss_index=12&num=1
you can google for suppliers.
andy.
ah, ok, you need something to convert 2 5.25 inch bays into 3 3.5 inch bays
yep, cant believe the only ones i can find are £70+ like the one on overclockers... gap in the market i think!
Do you have space at the bottom/floor of your case?
If you got you can use this to mount one of the drive to the bottom Zalman ZM-2HC2 you may need to drill 4 hole to fit the screw though.
and use this to mount the other 2 to your 5.25 bay Akasa Hard Drive Dampener 3.5" - 5.25"
im very surprised by this too.
the only cheaper options i can see are to get two 5.25 -> 3.5 inch adapters that i linked previously and either:
- house 1 outside the case with some sort of external HDD case thing
- find a 3.25" HDD cage which will house 1 HDD that can be screwed into your case somewhere
he said they are all 3.5" HDD's, so am i missing something from another thread?Just stick two of your SSD's together, and mount them in a conversion bay. Then have one seperate. They don't generate any heat or vibrate... so all is well. I ran mine like that for a while until I got a new case.... which may be a cheaper and better option for you than spending 80 quid on a bay.
iStarUSA TC-iStorm7 approx £30 at one site in uk (overstock.co*)
