Hi there.
I have a WD 14TB Elements Workbook (external HDD), plugged into my server, that I use for main storage.
I also have a spare 6TB WD Red that I want to start using for backups, so I need a HDD enclosure for it.
1. With hard drive enclosures, are they are much the same or should I look for anything specific? I have read that plastic ones can cause them to overheat, so aluminum is preferable. I also read that enclosures that stand on their side are better than flat as there is more surface area for the heat to come off. Might little real-world difference but would appreciate your thoughts.
2. Do the Workbook enclosures provide decent enough cooling or should I consider switching them around, so that the 14TB goes in the new enclosure instead? I really want the best case for the 14TB, as the other is only for backups.
