3 fans 1 header
Where the hot things are. Heatsinks, hard drives etc. Make sure the relevant fan is actually able go effect the temperature though.
all plugged in, currently running
230mm front intake
230mm top exhaust
140mm rear exhause
120mmx2 side intakes
placed 4 of the probes on the graphics card casing as thats my main reason for increasing fan speed, its gtx770 gigabyte edition.
my current temperatures never exceed 30 degrees and the average only goes up when the gtx is getting used
the card peaks at around 68 and ive set the fans to automaticly increase to 90% when 60 is reached in an attempt to move as much air as possible to the GPU
the other probe is taped on with the stickers provided to the heatsink on the CPU this probe is automated to fan 3, the rear exhaust, this then increases to suck as much air out as possible for the CPU, but i've never seen the cpu temperature rise because im using an Alpenfohn Brocken CPU cooler ( the fan is still connected to the motherboard CPU header)
