3 hard drives
29 Jun 2004
ok i have 2 HD connected via IDE and 2 drives a cd and dvd on the other cable. how then do i install a 3rd hard drive?thanks
welcome to the limits of ide :D
you can only av 2 per channel,
so you would need to go sata or scsi
or purchase a add in ide card / ata raid card
yup
2 per channel, normally 2 channels per motherboad.
You can however add an ide card, SATA card or SCSI card (if you are feeling flush), the chances are if your motherboard/system is reasonably newish it will have additional IDE or SATA connections to the standard 2 IDE channels.
you could use an external firewire HD box but you would be limiting the drives peformance to the firewire speed of 400, usb2 would be a little faster but not a lot in it to be honest. if its just storage and not required for speed then i would opt for a USB2 external hardrive unit. they come in many sizes one will surely suit your buget.
of course your PC needs to have USB2 or firewire to use either choice.
yeah mabye ext HD is the way to go cheers matey.
