I was just looking over my pre-order for a full new build.
I realised that for the antec300 i've ordered another 2 120mm case fans but i'm not sure with these being 3pin power connector's if they are the right ones considering the power supply i've ordered only has 4pin peripheral connector's.
The motherboard i've ordered says that it has these as internal power connector's 1 x CPU Fan connector , 1 x Chassis Fan connectors , 1 x Power Fan connector.
I'm really clueless as to whether i would be able to power these or even where they plug in (this is the first computer i've built for more than 5 years now).
Should i switch these 2 case fans to 4pin fans ?
