Remember that the 3rd lane's speed is x1 when using the 1st and 2nd slot. Got the same board as you.
3 x PCIe 2.0 x16 (x16, x8, x8 or x16, x16, x1)
Ok
I have no more unused PCIE cabel connectors on the PSU unit.
Can i use this http://www.overclockers.co.uk/showproduct.php?prodid=CB-018-AK&groupid=1929&catid=153&subcat= and connect to a PCIE cabel that is already connected to a Hard Drive.
Ok
no need to buy the adapters, they should be in the graphics card box.
ive had that psu for 2 yrs plus on 3 cards had the 5850's 1st now 3 6950's unlocked to 6970's just needs 2 molex to pcie power adaptors, very quiet psu aswell under full load.
Yeah the card will fit, ive had a sim setup with cards like that but he will need a case with 8 pci slots on back or able to over hang the last card like i have, also depending on the cards and fan size may need to cut his power switch,reset etc jumper plugs down in size as the card will sit on them.. :s
Which is exactly what I said at post #7.
