I was wondering how anyone can fit 3 graphics cards in their pc?
I have a compatible mobo, massive case, and 2 x BFG 8800 GTX OC2 at the moment, but if i wanted a third, then there simply isn't the room - or there is but we are talking about nanometres between the above and below GTXs.
Also, if 3 were to be fitted, then how on earth this there going to be any room for the air to enter the fan!!! crazy. Heat levels would probably reach 200*C!
I guess this is where you all tell me that unless you water cool your graphics cards, then 3 way SLI is not going to be possible.
cheers,
cheers,
