Well the topic says it all,
I currently have a WD Raptor 74gig drive and it is fine, no complaints however being a glutton for punishment I want to improve load times on games.
The question I have is, do I spend about £300 for a Adaptic 68pin U320 SCSI card and buy a 73gig 15K rpm drive?
Or do I try raiding a couple of WD raptors?
I would like to keep my OS intact at all times because I get narked having to reinstall it. Thus I need some data protection. I thought about RAID 5 - i.e 3 WD raptors. This would probably cost about £300 as well.
3rd option is to try out intel's matrix storage tech and put 2 WD raptors, half of the drives in raid 1 (OS) and the other half in RAID 0.
I have a P5WDH deluxe which I belive can do RAID 5 on SATA. So the question is....
What would you go for and why?
Also I would like to hear from those who are running MATRIX or who have tried it. Intel eludes to the fact you can just add another drive and have it build the array while you are still using the computer. This sounds great as I can migrate my OS from 1 drive to a raid setup without a reinstallation. Is this possible?
