3000+ to 3500+ much difference?
sr4470 said:
Multipler is locked on all standard Athlon 64s. Only FXs have unlocked multiplier.
Try running superpi in a loop and prime95.
Thats not a great board for overclocking by the way, or even in general..
Run them at the same time or separately?
Seperately, as its a single core. Suppose you could run them at the same time for maximum stress on the CPU\PSU. Prime95 running for 8-12 hours straight is a fairly good indicator of long-term stability.
Run them seperately, they serve different purposes:
SuperPi is a quick and dirty test of stability, if you can pass 8mb then you're doing ok.
I use a couple of hours of prime95 (or stress prime which has a nicer interface) to test for real usable stability, tbh 2 hours prime is long enough for me to get bored, and indicates good enough stability for my purposes.
Fair point.
Yeah, but I like to be totally sure as my rig is under 100% load 24\7 with DC projects.
No pount buying expensive ram because you pay that much more for it you may as well have got a more expensive cpu which defeats the object of getting a good value cpu.
I have my 3200+ at 2.7Ghz with Corsair 3200 value DDR. (1.45 volt on the cpu DDR on a 166 divider)
Thats how its currently running. Just been playing BF2 and it seems fine. Should I prime and superpi it now, or up it a bit more?
A[L]C said:
my.php
Up it some more, most Venice cores should be going to 2.4-2.6 on stock volts.
