3007 grahpic problem
1 Jan 2007
hi all just wandering if anyone could help me right i bought a dell 3007 wfp-hc 5 weeks ago fantastic monitor would reccomend to anyone but unfortunately i had an accident with mine last week after only 4 weeks of owning one ad dropped something onto it and breaking the screen anyway all was well before this misshap i have it covered on insurance etc etc so in the meanwhile had to use a lowly 19" for little over a week anyway got my replacement yesterday and when the pc has been running for a while i get little red dotted lines running from left to right mainly on darker sections of the monitor
now the only things that have changed since the first one breaking and getting the new one are i upgraded from an e6300 core duo to a q6600 and also upgraded my motherboard bios i have a gigabyte 965p ds3 i upgraded to the f12 bios so if anyone can help me in choosing which is the problem the quad core cpu the upgraded firmware or the monitor i wanted to change the firmware to rule it out but dont know how to go from hte latest firmware to an older one as the @BIOS utility wont let me any suggestions please
OUCH!! You have my sympathies.
Anyway, run both your 3007 and your 19" side by side from the same card (in clone mode). If both display the corruption, its not a monitor problem. If the 3007 shows the problem and the 19" doesnt, then its a faulty monitor and should be returned.
Good luck.
