I have a 3070ti FE and notice when the GPU is under high load I have a buzzing noise coming from my active monitor speakers. I tried most of the stuff I found online regarding ground loops and coil whine.
The noise is fine at idle, and even at high usage from the actual card (very little noise from inside the case) but because they are connected through USB to my Scarlett 2i2 audio interface then to two Yamaha HS5 active monitor speakers this amplifiies the noise when the GPU is under high power usage.
I have tried the following so far:
At this point I started to think my GPU under high load is leaking EMI into the motherboard which is causing it to travel through the USB ports. To test this theory I done a bit of "part swapping" with my son's PC. I should also mention he has a "similar" setup to mine (Ryzen 5600, Tomahawk B550)
I then also tried removing things like the 24pin extension cable, unplugged any SATA devices (corsair commander, HDD drives etc), still same issue.
I am close to just calling it a day and purchasing normal 2.1 speakers for my setup. I do prefer using these as I connect my guitar to the PC and use plugins and its nice to have them for general desktop/music/gaming usage too.
Does anyone know anything else I can try to solve this issue? The only thing I haven't attemped yet but the "his PSU not working in mine" put me off, was removing my motherboard/components and running the PC without the case, just in case there is a ground issue with that.
Thanks
- Different USB ports, different USB cable
- Powering the Scarlett 2i2 via TP Link UH720 powered USB hub
- Plugging the power leads into different sockets/seperate sockets
- Making sure the TRS 1/4" jack cables to my speakers are balanced (and even tried different cables)
- Removing everything else connected to the PC at the time of the noise (keyboard, ethernet, DP cable, bluetooth adapter, wireless mouse adapter)
- Purchased a iDefender+ USB Ground Loop & Power Noise dongle (this made a tiny difference, maybe 10-20% but for £60 it didnt justify fixing the issue compared to getting rid of my active monitor speaker setup)
- Attaching ferrite clips to the ends of my USB cable and balanced 1/4" cables
- Connected my USB cable, Scarlett 2i2, balanced cables and speakers to his current setup - NO ISSUES, this led me to think it must be the GPU that causes it
- Same setup as above but with my 3070ti FE installed - NO ISSUES (you could only hear coil whine from the actual card itself because the case was open not from the speakers, this now made me believe it was something within my current PC (motherboard, psu etc)
- Same setup as bove but with my RM750 installed - BUZZING FROM THE SPEAKER, this now made me think I have it, the PSU is the issue
Thanks
