Only issue is Roland Duo Capture EX isn't avaliable on Rainforest that I can see so would be a gamble with someone else. The Rubix22 is though but delivery not till mid April.
The Audient ID14 is on there but sold and dispatched by "someone else".
I appreciate all the information and help you have all sent, really making this easier to work through. Going to look at the ones you mentioned above but in a nutshell just now:
Possible "USB Ground Loop" issue but as the iDefender+ did not remove it completley my best option would be moving away from USB and going for OPTICAL.
Allthough I would have thought a £60 iDefender+ would have done a better job than the Behringer HD400 Hum Destoryer I have decided to order one of these anyone coming tomorrow to see if that works any better. If it does happy days and just shows a cheaper device can do a better job, if not then I'll return it and continue down the "OPTICAL" route.
In terms of going for an OPTICAL device I then have two options:
1 - Purchase a DAC for around £55-90 that only is used for the speaker side of it connecting to the PC with OPTICAL and powered via USB wall plug, this means I would keep my Scarlett 2i2 as a USB powered device ONLY for the guitar input side.
2 - Purchase a Audient ID14 for around £180 or similar audio interfaces mentioned above that will replace the Scarlett and allow me to both plug in my speakers and guitar with the advantage of using OPTICAL rather than USB to hopefully remove the buzzing issue from the GPU load.
And to clarifiy, I "ONLY" have this buzzing during under load GPU gaming, so this still applys the "ground loop" status? Or is this a red herring and is more "EMI"
Sound about right?
Sound about right?
