3080 MSI Trio X - Overclocking queries (3dmark and CoD:MW)
1440p RTX and AA off, most other settings to high, fps is locked at 141 and sits there most of the time, occasional dips below.
I presume me being Ultrawide at 1440p still requires more grunt (since more pixels lol)
I 110-120 with RTX and AA on I believe with similar settings. Its never noticably bad despite wanting to ensure I'm getting what I paid for.
Yes, I used MSI Afterburner.
0.875 mV with 1905 Mhz. Maybe I could get better results but I need time to actually test stability.
I still dont get it bud... does undervolting just help with temperatures? basically running the same performance but at a lower temperature?
How do you take advantage of undervolting? I.e. lower temps and then pushing the thresholds?
Folks... this is wierd.
The first scene in COD:CW, my FPS drops down to 48fps and then goes up to 55-60fps and then once I leave the bar it kind of hovers around 60-70fps.
But what I noticed was my GPU usage was always 50% and my CPU is 72% (so no CPU bottleneck surely). (monitor using RTSS/MSI)
Not sure whats going on.... can anyone do a quick test to see if its similar or are you all getting high GPU usage?
E: Tried CoDMW and Im getting more than 90% on the GPU.
Clearly something not right here...
