3080FE Upgrade
19 Nov 2004
Wokingham
Maxed out at 1440p in Cyberpunk 2077 my system gets a bit slow <30FPS, would a 4070 Super be a good upgrade or should I consider something else?
Ryzen 5 7600
3080 FE
Corsair Vengeance Black 32gb DDR5 5600MHz
Asus Tuf Gaming B650 Plus
Not overclocked, I guess that should be my first port of call.
The obvious cheap choice is reduce the settings. I think you’d struggle to tell the difference between most of the high settings.
A Ryzen 5 7600 is also a mid range CPU. A great one, but no escaping that it isn’t really a match for a 3080 FE in more difficult titles. Though it sounds like in this situation you’re mostly GPU limited.
Start with settings, and if you need to lower them to a point where visual quality evidently suffers, get a much stronger GPU rather than a lower tier but newer gen.
Thanks both. Will dial it back a bit and see how it goes.
What would be a good CPU match for the 3080 with my current hardware?
I completed Cyberpunk when it came out on a 3080 and that was on 3440x1440 UW. I had ray tracing on the 2nd highest setting (pre path tracing patch) and DLSS balanced. I was getting around 60 fps.
I don't know if the DLC update has made it more demanding in the main campaign.
I think there is mod for cyberpunk to add frame generation for 3000 series cards.
I've just gone from a 5600X to a 7800X3D and it didn't actually make much difference in Cyberpunk for me with a 4090. Probably as it's such a graphics hog.
Lots of other games saw much bigger gains though like Starfield , Elden Ring and especially Fallout London
The 3080 is still a high-end card, there's not really anything affordable and a big chunk faster to replace it with. TPU's spec page lists the 4070 Super as just 9% faster, though that is discounting "fake frames".
Do not get a 4070 super as an upgrade, it's barely any better, you'd need at least a 4070 ti super to really notice a difference, imo
I'm waiting on 2nd hand 4080 Supers when the next gen come out. I don't game as much as I used to and I've only got a 5800x3d to pair with it so that seems like a reasonable upgrade that shouldn't break the bank. Depends what people are willing to accept for their old cards I guess
Even a Ti SUPER is only about 30% faster - is that really worth it?
4080 SUPER or 4090 are the only really worthwhile upgrades tbh.
I certainly wouldn't bother going from a 3080 to a 4070 super. A friend was in a similar position (their 3080 had broke) and they wanted to replace the 3080 with something roughly equivalent (they didn't need more performance) - 4070 super was the closest thing really.
Been noticing drops in framerate on other games, specifically Robocop Rogue City. Playing in the settings maxed out and the GPU is not at full load but the CPU is and the framerate drops below 24fps. Starting to think my R5 7600 isn't up to the task. Any advice on a better AM5 CPU?
Well that's your problem. Thank UE for lousy performance.
My rule of thumb is only upgrade when 100% improvement (double framerate) is possible. So I went from 1080ti to 6800XT to 4090.
You have a 3080FE so you'd need a 4090 minimum to double your performance assuming no CPU bottleneck.
