- 21 Apr 2007
Even if that comes true the 3090 will still have more VRAM which will give it an advantage in some scenarios, DLSS vNew will be backward compatible for sure so the 3090 will get it as well. Anyone still claiming to be a PC gamer getting high-end hardware to use on 1080p needs their head examining.It won't. But what about it in a scenario where a £550 4070 is putting out;
- 20% faster @1080
- 10% faster at 2K and although a bit slower at 4k raster...
- 15% faster for DLS (upscaled) RTX @ 4K.
If you think its going to be still worth £600 come Jan, you had best hope there is an army of Maya users (not the type to go 2nd hand tbh [unless students]) are waiting to pick up 24gb cards.
Most importantly though is if a £50 loss in value concerns you deeply over a 6month period or 10% perf here or there is the difference between success and disaster... you really ought to be taking time out from PC hardware. Those sorts of variances are trivial.
The real risk is hardware failure and being left with an expensive problem, that could be an issue or it might not the point is to make sure you are aware as the buyer after that the risk appetite is yours to take or not as you see fit imho. Personally I wouldn't do it but everyone has their inflection point.
I`d half expect crusty thermal paste / pads but memory degradation . not a clue.
