No because the lists are never complete. And they also don't provide an
incompatible list. Those lists are for those buying new RAM who want to be sure it has been tested on the board but it should not be seen as an "oh well, your memory is incompatible, so too bad for you" thing.
Back to - the VCCIO Mem OC and System Agent remain low for Rocket Lake*. You may need to wait for a BIOS update for either better compatibility out of the box, or to sort out any issues you are still experiencing when attempting to modify voltages.
* Remember, I'm having to use 1.3v on mine (11700 - 3600MHz) and out of the box with mine it was 1.6v.
In the following thread there is a Shamino, who may or may not be the actual Shamino of Asus ROG fame -
https://rog.asus.com/forum/showthre...A-voltage-after-loading-XMP!-1-638V!-Be-aware
Regardless of who that guy is (and he is a Super Moderator), he mentions that a co-worker says high SA voltage is required for non-K chips on Rocket Lake, but that he, Shamino, is trying to convince him to do the same for the K chips. Inferring that when a K chip like yours is installed, the BIOS may not be setting enough SA just now.
